Trouble shooting injectors |
LanceW3544 |
Jul 29 2018, 02:38 PM
Newbie Group: Members Posts: 13 Joined: 25-July 18 From: Grand Rapids Mi Member No.: 22,337 Region Association: None |
First of all forgive my lack of knowledge. I am not new to cars but I am new to 914s. I recently purchased a 1970 914 1.7L. with D. Jet. The previous owner noted that it ran last year but was not able to get running this year. The car is far from perfect but I hope to be a solid start for a EJ20 swap in the next year or so. I would love to get the 1.7 fired up to start taking care of of other issues I am not currently aware of.
So let me start discribing what I am seeing Good Battery- Cranks over good and for a long time if needed Fuel Pump- working well but does not shut off after 1-2 seconds. New plugs New wires New cap and rotor I check the fuel rail and I know I have fuel to the injectors. I am able to fire the car up with starter fluid but ofcourse dies when it is burned off. I have had it runnig several times but is not consistant. I have check the grounds to the batter as well as the injector grounds. I don't know where to go next. Any advice would be appreciated. As you explain your suggestion please don't use abbrevations as I am not framilar with them all yet. Thanks -lance |
mepstein |
Jul 29 2018, 03:25 PM
914-6 GT in waiting Group: Members Posts: 19,511 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I send all our injectors to mr injector. Even if they work, he flow tests before and after cleaning and replaces the seals and hose. $17 each + 6 shipping. Then at least you know you are getting an even amount of fuel to each cylinder. If he can’t get an injector to flow correctly, there’s no charge. I sent him at least 150 injectors in the past couple years.
Lo-Fi Version | Time is now: 24th September 2024 - 01:04 PM |
