Trouble shooting injectors |
LanceW3544 |
Jul 29 2018, 02:38 PM
Newbie Group: Members Posts: 13 Joined: 25-July 18 From: Grand Rapids Mi Member No.: 22,337 Region Association: None |
First of all forgive my lack of knowledge. I am not new to cars but I am new to 914s. I recently purchased a 1970 914 1.7L. with D. Jet. The previous owner noted that it ran last year but was not able to get running this year. The car is far from perfect but I hope to be a solid start for a EJ20 swap in the next year or so. I would love to get the 1.7 fired up to start taking care of of other issues I am not currently aware of.
So let me start discribing what I am seeing Good Battery- Cranks over good and for a long time if needed Fuel Pump- working well but does not shut off after 1-2 seconds. New plugs New wires New cap and rotor I check the fuel rail and I know I have fuel to the injectors. I am able to fire the car up with starter fluid but ofcourse dies when it is burned off. I have had it runnig several times but is not consistant. I have check the grounds to the batter as well as the injector grounds. I don't know where to go next. Any advice would be appreciated. As you explain your suggestion please don't use abbrevations as I am not framilar with them all yet. Thanks -lance |
Dave_Darling |
Jul 29 2018, 10:11 PM
914 Idiot Group: Members Posts: 14,994 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Your engine needs three things to run: Fuel, air, and spark.
An extra spark plug with the threaded part taped to a ground hooked up to one of your plug wires should show visible sparks when you crank the starter. You can remove the injectors from one side of the motor (one M6 nut/10mm head each) and put the injectors into a jar. They should spray when you crank the starter. Or you can see if the tailpipe smells of fuel after cranking the starter for a while. A compression test will tell you if you are getting air. I would suggest making sure that all wires and hoses are plugged in securely to the right places. That's a very worthwhile first step... --DD |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:42 PM |
