Capacitive Discharge Ignition, Any benifits to using the MSD system? |
Driver174 |
Jul 30 2018, 08:33 PM
Member Group: Members Posts: 107 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
914-4 2L race engine, 10.3:1 compression ratio and twin Weber's
Anyone have experience with the MSD systems on a Type IV? I'm thinking there may be benifits to having the higher spark voltages when compression ratio is relatively high. MSD claims plug gaps of .050 - .060" are possible, and that multiple sparks at lower RPM's improve throttle response. Thus, makes sense, but does anyone have real world experience that support these claims? |
Mark Henry |
Jul 30 2018, 10:20 PM
Yes and no (IMG:style_emoticons/default/biggrin.gif)
In your case the with the much higher than stock CR it very likely helps. Stock or stockish CR would be debatable. With that CR you definitely need high octane race gas and/or twinplug. |
Lo-Fi Version | Time is now: 25th September 2024 - 10:53 PM |
