BPGREER |
Member ![]() ![]() Group: Members Posts: 131 Joined: 29-September 04 From: SAN FRANCISCO Member No.: 2,857 ![]() |
OK, I'm once again stumped. My car just won't idle smoothly. It sounds like it's going to die, but then revs itself up a bit, then almost stalls again, then revs again... So, I thought it might be a vac leak. I had already replaced all of the hoses, but found that I had leaks on the air intake runner things, where they connect to the plennum. So, I disassembled everything, replaced those hose-type things, and voila! No more vac leak there. Problem is, still not idling right. It's just as bad now as before. One more thing, I slowly brought up the rpms from the throttle body, to listen, and I think I heard a couple of really quiet backfires. Maybe an exhaust leak? Could this cause a bad idle? Thanks.
Brian |
mike_the_man |
I like stuff! ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 ![]() |
(IMG:style_emoticons/default/agree.gif) with what Geoff just said. A hunting idle is often caused by a lean mixture. Once you're sure everything else is good, adjust the ECU. Sounds like you're getting very close.
An exhaust leak will usually backfire. I had a bunch of leaks where the heat exchanger bolts up to the head. If you stick your head down there with the car running, you can hear it backfiring, and can see or feel exhaust blowing out as well. When I had exhaust leaks, it caused a pretty eratic idle. It probably wouldn't hurt to crawl under and make sure everything is sealed up. I can't remember the correct torque for the nuts, off hand. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:39 AM |
