Trouble shooting injectors |
LanceW3544 |
Jul 29 2018, 02:38 PM
Newbie Group: Members Posts: 13 Joined: 25-July 18 From: Grand Rapids Mi Member No.: 22,337 Region Association: None |
First of all forgive my lack of knowledge. I am not new to cars but I am new to 914s. I recently purchased a 1970 914 1.7L. with D. Jet. The previous owner noted that it ran last year but was not able to get running this year. The car is far from perfect but I hope to be a solid start for a EJ20 swap in the next year or so. I would love to get the 1.7 fired up to start taking care of of other issues I am not currently aware of.
So let me start discribing what I am seeing Good Battery- Cranks over good and for a long time if needed Fuel Pump- working well but does not shut off after 1-2 seconds. New plugs New wires New cap and rotor I check the fuel rail and I know I have fuel to the injectors. I am able to fire the car up with starter fluid but ofcourse dies when it is burned off. I have had it runnig several times but is not consistant. I have check the grounds to the batter as well as the injector grounds. I don't know where to go next. Any advice would be appreciated. As you explain your suggestion please don't use abbrevations as I am not framilar with them all yet. Thanks -lance |
Dave_Darling |
Jul 31 2018, 10:22 AM
914 Idiot Group: Members Posts: 14,994 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Do you have a "noid light"? Or some other light that can react to very short power pulses? If so, plug that into an injector plug to see if the electrical signal is getting there when the starter cranks.
The MPS is the hand-grenade thing with one hose and a four-wire plug going to it that sits below the battery. The trigger points are in the base of the distributor, with the three-wire plug down in front of it. Again, check all of the wires, plugs, and hoses. Make sure nothing has come loose. --DD |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:00 PM |
