Driver174 |
Member ![]() ![]() Group: Members Posts: 107 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None ![]() ![]() |
914-4 2L race engine, 10.3:1 compression ratio and twin Weber's
Anyone have experience with the MSD systems on a Type IV? I'm thinking there may be benifits to having the higher spark voltages when compression ratio is relatively high. MSD claims plug gaps of .050 - .060" are possible, and that multiple sparks at lower RPM's improve throttle response. Thus, makes sense, but does anyone have real world experience that support these claims? |
Driver174 |
On our 1.8 FProd car (12.3:1 CR) CDI made zero power difference. It did crap out, though, while leading a race at Barber. I rigged up a back up system I could switch back and forth between on the fly. The back up was a Bosch Blue Coil with no CDI. We tested both systems on the chassis dyno and there was absolutely zero difference in torque or power. We were using a Mallory distributor. Crank fire might be a different story. We ditched the CDI and the attendant complications. Thanks for sharing; this is exactly the information that I was needing. There is no sense in duplicating what has been proven in the past, and saves me time and money! As for crank fire set-up, I wish I could, but rules do not allow it. Jim |
Lo-Fi Version | Time is now: 24th June 2024 - 07:26 AM |
