my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
IronHillRestorations |
Jul 31 2018, 05:09 PM
I. I. R. C. Group: Members Posts: 6,762 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
If you have a contaminant on the surface no amount of paint will fix that, you'll only be making it worse by adding more paint on top.
Practice on something else besides your 914 (IMG:style_emoticons/default/smile.gif) |
worn |
Jul 31 2018, 05:23 PM
can't remember Group: Members Posts: 3,291 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
If you have a contaminant on the surface no amount of paint will fix that, you'll only be making it worse by adding more paint on top. Practice on something else besides your 914 (IMG:style_emoticons/default/smile.gif) With paint so pricey, I have to practice on my car. Or perhaps I should say experiment. I am having the same problem as the OP has described, only my conclusion is solvent pop more than orange peal (also potentially OP). I think some of us reason like I do, thinking if I get enough paint on I can just color sand to what I want. Good plan except for when you lay down Swiss cheese for paint. Also, a supplied air system is very much worth considering. It is an extra hose to drag around, but the paint chemicals are hard on the body. One alternative that looks like a winner is a scuba tank and regulator. eBay or Craig’s should be a help there. |
Lo-Fi Version | Time is now: 28th September 2024 - 05:09 PM |
