Trouble shooting injectors |
LanceW3544 |
Jul 29 2018, 02:38 PM
Newbie Group: Members Posts: 13 Joined: 25-July 18 From: Grand Rapids Mi Member No.: 22,337 Region Association: None |
First of all forgive my lack of knowledge. I am not new to cars but I am new to 914s. I recently purchased a 1970 914 1.7L. with D. Jet. The previous owner noted that it ran last year but was not able to get running this year. The car is far from perfect but I hope to be a solid start for a EJ20 swap in the next year or so. I would love to get the 1.7 fired up to start taking care of of other issues I am not currently aware of.
So let me start discribing what I am seeing Good Battery- Cranks over good and for a long time if needed Fuel Pump- working well but does not shut off after 1-2 seconds. New plugs New wires New cap and rotor I check the fuel rail and I know I have fuel to the injectors. I am able to fire the car up with starter fluid but ofcourse dies when it is burned off. I have had it runnig several times but is not consistant. I have check the grounds to the batter as well as the injector grounds. I don't know where to go next. Any advice would be appreciated. As you explain your suggestion please don't use abbrevations as I am not framilar with them all yet. Thanks -lance |
mgphoto |
Aug 1 2018, 09:01 AM
"If there is a mistake it will find me" Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Pump keeps running after the 2 second interval means someone fiddled with the relays on the relay board.
LanceW3544 |
Aug 1 2018, 09:17 AM
mgphoto |
Aug 1 2018, 09:27 AM
Pump keeps running after the 2 second interval means someone fiddled with the relays on the relay board. All three relays are there. Are each of them interchangeable? They are interchangeable but they must align correctly, the pins will fit and you may get some function. The relays will fit in the socket several different ways but only one is correct. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:19 PM |
