Driver174 |
Member ![]() ![]() Group: Members Posts: 107 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None ![]() ![]() |
914-4 2L race engine, 10.3:1 compression ratio and twin Weber's
Anyone have experience with the MSD systems on a Type IV? I'm thinking there may be benifits to having the higher spark voltages when compression ratio is relatively high. MSD claims plug gaps of .050 - .060" are possible, and that multiple sparks at lower RPM's improve throttle response. Thus, makes sense, but does anyone have real world experience that support these claims? |
HAM Inc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None ![]() |
We all know the hemi chamber with dome pistons is a bitch for flame propagation, no doubt about that. I can definitely see the CDI helping in that design.
Our shift point was around 7800, but at Roebling Road I did stretch 3rd to 8100 or so. One of the things that puzzles me about the multiple spark discharge concept when using a distributor is, how broad a crank angle can the rotor distribute spark in a given firing cycle. Without a special rotor, I don't think it could be as many as 20 crank degrees, which IRRC is what MSD advertised. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
We all know the hemi chamber with dome pistons is a bitch for flame propagation, no doubt about that. I can definitely see the CDI helping in that design. Our shift point was around 7800, but at Roebling Road I did stretch 3rd to 8100 or so. One of the things that puzzles me about the multiple spark discharge concept when using a distributor is, how broad a crank angle can the rotor distribute spark in a given firing cycle. Without a special rotor, I don't think it could be as many as 20 crank degrees, which IRRC is what MSD advertised. I agree, I was always dubious about jacobs ignition claims, basically it was just a multi spark CDI and at speed there's only time for a few sparks. Evidence points that it likely it does help low speed issues, but once over say 3000rpm it has little, if any, effect. I would think the hotter spark helps with the initial firing, probably more important on the /6 chamber, but little more To me it's much like the sequential and batch firing of injectors arguement. At low rpms where watercooled cars can run it will make a difference in fuel economy, but little effect on car that normally runs at 3000+rpm. Only so much can be achieved at higher piston/rotation speeds. |
HAM Inc |
We all know the hemi chamber with dome pistons is a bitch for flame propagation, no doubt about that. I can definitely see the CDI helping in that design. Our shift point was around 7800, but at Roebling Road I did stretch 3rd to 8100 or so. One of the things that puzzles me about the multiple spark discharge concept when using a distributor is, how broad a crank angle can the rotor distribute spark in a given firing cycle. Without a special rotor, I don't think it could be as many as 20 crank degrees, which IRRC is what MSD advertised. I agree, I was always dubious about jacobs ignition claims, basically it was just a multi spark CDI and at speed there's only time for a few sparks. Evidence points that it likely it does help low speed issues, but once over say 3000rpm it has little, if any, effect. I would think the hotter spark helps with the initial firing, probably more important on the /6 chamber, but little more To me it's much like the sequential and batch firing of injectors arguement. At low rpms where watercooled cars can run it will make a difference in fuel economy, but little effect on car that normally runs at 3000+rpm. Only so much can be achieved at higher piston/rotation speeds. Agreed. A crank fired C.O.P. ignition with smart technology firing continuously over 20 crank degrees might or might not benefit the flat-top two valve T4 chamber, I wouldn't bet a nickle that it would. But I'd bet the farm it would help a hemi with a domed piston, a lot. The bigger the dome the more helpful, obviously. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:52 AM |
