my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
Rav914 |
Aug 2 2018, 09:17 AM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
Man this is a clinic. Almost makes me want to try to paint my own car. Jump in and do it. I'm on my second car; bare metal repaint in the original color. This is after two coats of single stage. Still 2-3 more coats to apply. Once you learn how to do it, you'll look at car purchases differently. It's an enormous of work, the most I've had to do, but super rewarding and saves a TON of money. Attached image(s) |
Lo-Fi Version | Time is now: 29th June 2024 - 12:56 AM |
