914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: ![]() After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: ![]() Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
914 RZ-1 |
I found it! Thanks! (IMG:style_emoticons/default/beerchug.gif)
https://www.shop.softsanders.com/Super-Flex...andpaper_c8.htm Eastwood also has it, but they are out of 800 grit. They were a bit cheaper on the shipping, but not by much. |
Lo-Fi Version | Time is now: 29th June 2024 - 12:39 AM |
