1.7 VS 1.8 Engine Rebuild .. |
Beakster |
Aug 1 2018, 10:22 PM
Member Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None |
Hi Guys .. I'm being told that it is better to rebuild a 1.8 to get more torque from the engine then rebuilding the 1.7 .. and even the 2.0 casing .. would love a 2.0 but they are getting harder to find .. Is this TRUE ... If I should look for a 1.8 then spend too much $$$ in my 1.7 .. What's your thoughts ... ???
McMark |
Aug 5 2018, 07:44 AM
I had a motor (from back when I was JUST getting into cars) that I put new rings on. Ran it only a few 100 miles and parked it for awhile. The new rings and the cylinders were still breaking in, so they were still scraping each other and exposing bare metal. When I parked it, condensation probably caused corrosion. There wasn't enough oil residue built up to prevent it. Tried everything to break it free and had no success.
I would suggest that even if you do manage to break it free, assume it's damaged, at least slightly. I would suggest disassembling it and seeing what you have, then making a plan. But don't do anything unless you're prepared to spend at least $2k on the build. And if you're upgrading components, it can easily rise to $5k-$7k -- more if you've having a shop do the work. |
Lo-Fi Version | Time is now: 27th December 2024 - 12:14 PM |
