1.7 VS 1.8 Engine Rebuild .. |
Beakster |
Aug 1 2018, 10:22 PM
Member Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None |
Hi Guys .. I'm being told that it is better to rebuild a 1.8 to get more torque from the engine then rebuilding the 1.7 .. and even the 2.0 casing .. would love a 2.0 but they are getting harder to find .. Is this TRUE ... If I should look for a 1.8 then spend too much $$$ in my 1.7 .. What's your thoughts ... ???
r_towle |
Aug 5 2018, 03:05 PM
Custom Member Group: Members Posts: 24,663 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Pour marvel mystery oil in each cylinder via the spark plug hole , leave plug out.
Put car in fifth, Tow car backwards then forward with another car. It will eventually give up. Then dump the oil, put in cheap oil ( you will change it a few times) Fire it up. Get it warm check compression. |
Lo-Fi Version | Time is now: 27th December 2024 - 12:29 PM |
