1.7 VS 1.8 Engine Rebuild .. |
Beakster |
Aug 1 2018, 10:22 PM
Member Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None |
Hi Guys .. I'm being told that it is better to rebuild a 1.8 to get more torque from the engine then rebuilding the 1.7 .. and even the 2.0 casing .. would love a 2.0 but they are getting harder to find .. Is this TRUE ... If I should look for a 1.8 then spend too much $$$ in my 1.7 .. What's your thoughts ... ???
r_towle |
Aug 5 2018, 03:05 PM
Custom Member Group: Members Posts: 24,663 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Pour marvel mystery oil in each cylinder via the spark plug hole , leave plug out.
Put car in fifth, Tow car backwards then forward with another car. It will eventually give up. Then dump the oil, put in cheap oil ( you will change it a few times) Fire it up. Get it warm check compression. |
mb911 |
Aug 5 2018, 03:36 PM
914 Guru Group: Members Posts: 7,370 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Pour marvel mystery oil in each cylinder via the spark plug hole , leave plug out. Put car in fifth, Tow car backwards then forward with another car. It will eventually give up. Then dump the oil, put in cheap oil ( you will change it a few times) Fire it up. Get it warm check compression. Thats what dad did on his and broke it free. Listened to it run for the 1st time in 10 or so years last week. |
Lo-Fi Version | Time is now: 27th December 2024 - 12:32 PM |
