Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Well, I promised a while ago that if I could get ahold of a program for drawing scematics I would make some quick troubleshooting diagrams for us all. I got Visio2000 and it seems to be adequate for this so I will start posting my schematics as I draw them. If no one is interested let me know and I'll just keep this to myself. Just thought that I might help.
First is the circuit that causes much head ach with the D-jet system. "Why is my fuel pump fuse blowing?" Usually it is because the Auxilary Air Valve is shorting to the block at the plug, but here are the other things involved. This is of the fuse/relay panel in the left engine compartment: B+ is the positive side of the battery. The pointy parts at the end of some of the lines are ground. Consider all grounds to be the same place and to be connected to the negative side of the battery through the cars body. Ask questions if you need clarification. Attached thumbnail(s) ![]() |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I would like to see the headlight system. I want to have my switch set up so only the orange corner lights ( front and rear) come on first; then the license plate, reds, and headlights come on with full on.
If your diagram can help me make this change, it would be greatly appreciated. Jim |
Lo-Fi Version | Time is now: 26th June 2024 - 05:42 AM |
