914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: ![]() After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: ![]() Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Thinking back, I do remember having this issue once. I think I ended up going with a different filter for that particular job or not using one alltogether.
looking back over my paint thread, I notice this picture (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1304697293.2.jpg) You can see the filter near the tank. I wonder if moving it farther away from the gun and before the regulator could help? You can see its not on my gun in this pic of me spraying the car. (IMG:http://www.914world.com/bbs2/uploads/post-172-1305529585_thumb.jpg) |
914 RZ-1 |
I've got similar orange peel on my hoods; were you able to color sand and buff that out?
I've got two filters in addition to the one at the gun. It goes like this: compressor>25' coiled air hose>2 moisture removing filters> small hose to reel>50' hose (might be 25') on reel>pumpkin filter>regulator>gun Maybe I'll put the filter closer as you suggest. Thanks for the input! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 29th June 2024 - 01:04 AM |
