> Beyond frustrated!, installation of triangle seal, glass , and front track- seal too long, tight, door cant shut and to top it off the bottom adjuster, was stuck, broke!
DRPHIL914
post Aug 11 2018, 04:49 PM
Dr. Phil
beyond frustrated- i am going to have to source a replacement assembly with a good adjuster- anyone have one send my way cheap or free??
spent the better part of the last 4 hours trying to get the doors done. unable to complete because the drivers door bottom adjuster nut that is attached to the front track that also holds the triangle window was rusted bad and snapped off- second was , before that happened being unable to get triangle glass seal in(too long) and down enough so could not get door to shut.
pulled it all back out and now i cant decide how to proceed!
Mikey914
post Aug 12 2018, 01:31 AM
The rubber man
Has Matt followed up with you. He did the install and still is working on the install guide, but has the steps laid out. Yes, the install needs to be done in a certain order, and there are some techniques to installing that help. This is not a easy install, that's why most body shops just tape around them if you let them.
Let me know if I need to reach out to him, but I thought he might already be on this.
Mark
Philip W.   Beyond frustrated!   Aug 11 2018, 04:49 PM
Philip W.   i know that 914rubber makes almost all seals a bi...   Aug 11 2018, 04:57 PM
914_teener   i know that 914rubber makes almost all seals a b...   Aug 11 2018, 10:42 PM
horizontally-opposed   Let me guess...factory seals? Been where you are...   Aug 11 2018, 05:00 PM
Philip W.   well if thr door shuts i can drive it with out a w...   Aug 11 2018, 05:33 PM
Philip W.   they are 914rubber seals- got the whole kit, fuzzi...   Aug 11 2018, 05:34 PM
horizontally-opposed   they are 914rubber seals- got the whole kit, fuzz...   Aug 11 2018, 07:30 PM
Chris H.   I might have that nut/bolt. Lemme look. You can ...   Aug 11 2018, 05:37 PM
Chris H.   You just need this bolt/nut combo correct? Migh...   Aug 11 2018, 08:34 PM
Philip W.   You just need this bolt/nut combo correct? Mig...   Aug 11 2018, 11:07 PM
horizontally-opposed   You just need this bolt/nut combo correct? Mi...   Aug 11 2018, 11:39 PM
raynekat   Philip W....I feel (and know) your frustration. I...   Aug 11 2018, 10:18 PM
Philip W.   Philip W....I feel (and know) your frustration. ...   Aug 11 2018, 11:02 PM
Mikey914   Has Matt followed up with you. He did the install ...   Aug 12 2018, 01:31 AM
billh1963   Phil...I got my GB harness in last week. If you ar...   Aug 12 2018, 07:30 AM
Matty900   I did some video as I installed it in my car. I am...   Aug 12 2018, 02:13 PM
Philip W.   I did some video as I installed it in my car. I a...   Aug 12 2018, 05:46 PM
tmc914   That triangle seal was difficult indeed. Started w...   Aug 12 2018, 07:20 PM
raynekat   That triangle seal was difficult indeed. Started ...   Aug 12 2018, 11:23 PM
Philip W.   That triangle seal was difficult indeed. Started ...   Aug 23 2018, 08:58 AM
raynekat   Here's another pic/view of the offending area ...   Aug 12 2018, 11:24 PM
raynekat   This view shows again where the leading edge of th...   Aug 12 2018, 11:27 PM
raynekat   Side view of the seal installation. Again, it is s...   Aug 12 2018, 11:35 PM
carl k   I have this driver's side frame if you ne...   Aug 13 2018, 08:43 AM
Philip W.   I have this driver's side frame if you n...   Aug 13 2018, 09:20 AM
Philip W.   Side view of the seal installation. Again, it is ...   Aug 13 2018, 09:22 AM
Mikey914   Guys on the width of the seal, you are comparing i...   Aug 13 2018, 09:08 AM
Philip W.   Guys on the width of the seal, you are comparing ...   Aug 13 2018, 09:18 AM
Philip W.   maybe this should be a Tech Session #5 at Okteener...   Aug 13 2018, 09:25 AM
Mikey914   Actually its on the schedule as door rebuild but t...   Aug 13 2018, 10:47 AM
Philip W.   Actually its on the schedule as door rebuild but ...   Aug 13 2018, 11:02 AM
Philip W.   update: well last night I decided I would try the...   Aug 22 2018, 06:27 AM
Philip W.   I may just put the windows, frames and seals in my...   Aug 22 2018, 06:52 AM
Matty900   I may just put the windows, frames and seals in m...   Aug 23 2018, 12:16 PM
dr914@autoatlanta.com   Have you tried the URO vent glass seals to compare...   Aug 23 2018, 09:04 AM
Philip W.   Have you tried the URO vent glass seals to compar...   Aug 23 2018, 09:11 AM
Mikey914   You can try the URO seal, but if the top cap fits ...   Aug 23 2018, 10:47 AM
Philip W.   You can try the URO seal, but if the top cap fits...   Aug 23 2018, 11:04 AM
Mikey914   To be honest this one had me swearing quite a bit ...   Aug 23 2018, 11:20 AM
Philip W.   To be honest this one had me swearing quite a bit...   Aug 23 2018, 12:41 PM
16 User(s) are reading this topic (16 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 07:21 PM
