> Making Your Flasher Relay LED Compatible
Spoke
post Dec 31 2015, 08:43 AM
Jerry
This thread is meant to help those implementing LED turnsignals on their 914.
Standard flasher relays were designed to flash 2 standard bulbs (21W each) for turnsignals or 4 standard bulbs with 4-ways on.
LED replacements burn between 2W and 5W and electrically may not behave at all like a standard bulb. The LED replacements can cause all kinds of weird things like hyperflash (2x normal flash rate), dash indicators do not work, or the the flasher relay does nothing at all.
The 914 flasher is different for early cars 70-73 than later 74+ mainly because of the tach indicators. Early cars have individual L and R indicators and the 74+ have a single L+R indicator. Both are handled differently by the flasher.
There are LED-compatible flashers generally available at your FLAPS which are plug-in but not totally function compatible with the 914 standard flasher. The functional issue revolves around the 4th terminal which the 914 uses to activate the dash indicators.
The aftermarket flasher relays are EP26 (4 terminal) and EP36 (3 terminal). I've seen these at Pep Boys, Autozone, and Advance Auto to name a few FLAPS, usually for less than $15.
I'll detail the differences between early and late cars, as well as EP26 and EP36 in the next few posts.
tmc914
post Aug 16 2018, 05:41 PM
This is helpful. Changed the lamp for the m/c dash indicator and with e-brake on both turn signal dash indicators flash crazy. Ordered a modified EP26 relay from Spoke and will see what that does to help. If it does not fix the problem then I'll put a higher wattage lamp in the dash indicator.
Spoke
post Aug 16 2018, 09:51 PM
Jerry
QUOTE(tmc914 @ Aug 16 2018, 07:41 PM) *
What did you change the m/c dash indicator to? LED or other incandescent bulb? The OEM flasher was designed to flash normally with very little current to flash the m/c indicator with a 1 sec flash rate. Thus the OEM flasher doesn't hyperflash when LED turnsignals are installed. With the light m/c indicator current, the turnsignal dash indicators shouldn't flash.
In comparison, the 911 OEM flasher hyperflashes when one front or rear turnsignal is changed to LED. There's no debate that if the exterior turnsignals are converted to LEDs, the flasher must be changed to EP26.
EP26 will solve your turnsignal dash indicator issues. They will work normally although you'll find that after installing EP26, the L indicator will flash with the right turnsignals and the R indicator with the right turnsignals. To fix, simply pop the tach out and pull both indicator sockets out and swap positions.
Spoke   Making Your Flasher Relay LED Compatible   Dec 31 2015, 08:43 AM
falcor75   Are you still making your led lights Spoke? I...   Dec 31 2015, 09:03 AM
jmill   Are you still making your led lights Spoke? I...   Dec 31 2015, 09:56 AM
Chris H.   Could you cover converting the single indicator to...   Dec 31 2015, 10:00 AM
Spoke   Could you cover converting the single indicator t...   Dec 31 2015, 10:33 AM
Spoke   '70-'73 914 with separate L and R dash ind...   Dec 31 2015, 10:25 AM
porsche913b_sp   '70-'73 914 with separate L and R dash in...   Dec 31 2015, 09:35 PM
Spoke   I have a spare early flasher relay I can donate to...   Jan 1 2016, 05:33 PM
Spoke   '74+ 914 with single L/R dash indicator. This...   Jan 1 2016, 06:33 PM
peteyd   Awesome! Giving credit where credit is due, t...   Aug 2 2018, 07:41 PM
Mark Henry   Very cool, I made my own flasher for my 67 bug. It...   Aug 12 2018, 04:16 PM
Spoke   Continuing the discussion of the early 914 ('7...   Aug 14 2018, 09:57 PM
Spoke   When LED turnsignals are installed, funny things h...   Aug 14 2018, 10:17 PM
ClayPerrine   When LED turnsignals are installed, funny things ...   Aug 16 2018, 01:03 PM
Vacca Rabite   I wish I had seen this earlier. Now that I've...   Aug 16 2018, 07:32 AM
worn   I wish I had seen this earlier. Now that I'v...   Aug 16 2018, 02:49 PM
worn   Nominate as a classic. LEDs may not be a flash in...   Aug 16 2018, 02:53 PM
tmc914   This is helpful. Changed the lamp for the m/c dash...   Aug 16 2018, 05:41 PM
Spoke   This is helpful. Changed the lamp for the m/c das...   Aug 16 2018, 09:51 PM
Gatornapper   Spoke - All LED's in my '76 914 and all a...   Mar 22 2023, 07:11 AM
GregAmy   All LED's in my '76 914 and all are worki...   Dec 15 2023, 12:54 PM
Gatornapper   Greg - sorry I just caught this. We think alike. ...   Jan 3 2024, 06:50 PM
GregAmy   Actually discovered that the LEDs in front the br...   Jan 4 2024, 10:19 AM
Gatornapper   MY BAD! All works fine on my 914. It's m...   Jan 3 2024, 06:52 PM
914werke   So is this applicable to the late Tach with combin...   Aug 16 2018, 08:58 PM
Spoke   So is this applicable to the late Tach with combi...   Aug 16 2018, 09:39 PM
FourBlades   I finally applied the jumper fix described by Spok...   Dec 14 2021, 08:29 PM
Robarabian   Second nomination for Classic Thread.   Dec 14 2021, 09:38 PM
barefoot   Here is Spoky's mod for the late single dash i...   Mar 21 2023, 07:23 AM
Geezer914   Converted the EP26 flasher. Turn signals work fin...   Mar 22 2023, 07:28 AM
rfinegan   Watching...my 75 is now flashing with the parking ...   Dec 15 2023, 02:02 PM
Spoke   Watching...my 75 is now flashing with the parking...   Dec 15 2023, 05:17 PM
VaccaRabite   Moved this thread to the Classics forum   Mar 22 2023, 08:27 AM
Red76   This link to show Spoke’s easy mod works. I just...   Dec 15 2023, 11:56 AM
rfinegan   Thanks Spoke...good write up   Dec 15 2023, 06:48 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:36 AM
