> How your Headlight Motors Work., A description with pictures.
ClayPerrine
post Nov 18 2004, 09:02 AM
NOTE: DUE TO MY NOT LOOKING AT THE WIRING DIAGRAM BEFORE POSTING THIS, I HAVE EDITED IT TO REFLECT REALITY!! (IMG:style_emoticons/default/headbang.gif)
I noticed that there is a lot of questions out there relating to how the headlight motors work. So I put this together to see if I can clear it up.
The headlight motor circuit functions like a 3 way light switch in your house. You all have seen them. The one you can turn on at the bottom of the stairs and turn off at the top. Well, when you turn on the headlights in a 914, you turn on the headlight motor. It's rotation turns off the headlight motor when the lights are up, using a set of wiper contacts in the motor.
In the first diagram below, I outline the headlight circuit with the lights in the down position.
jfort
post Nov 18 2004, 11:02 AM
this needs to go in Classics or whatever it is -- the place for reference material. great job!
ClayPerrine   How your Headlight Motors Work.   Nov 18 2004, 09:02 AM
ClayPerrine   In the next picture we see the headlight circuit w...   Nov 18 2004, 09:10 AM
Root_Werks   Cool! :trophy:   Nov 18 2004, 09:11 AM
ClayPerrine   When the headlights are all the way up, the wiper ...   Nov 18 2004, 09:13 AM
ClayPerrine   Now we turn the headlights off. The headlight swi...   Nov 18 2004, 09:17 AM
ClayPerrine   I hope that clears up the mystery of how the headl...   Nov 18 2004, 09:18 AM
mikerose   :clap: Thanks Clay :clap:   Nov 18 2004, 09:27 AM
dralf   :clap: Thanks, At the moment I am not having pr...   Nov 18 2004, 09:34 AM
ppickerell   Wow, you should try out for admin! ;)   Nov 18 2004, 09:46 AM
jfort   this needs to go in Classics or whatever it is -- ...   Nov 18 2004, 11:02 AM
ClayPerrine   Bump... updated to reflect the reality of the wiri...   Nov 18 2004, 12:51 PM
Gint   Nice work Clay. Many thanks.   Nov 18 2004, 12:52 PM
chunger   Sweet! I was thinking about using an aftermar...   Nov 18 2004, 03:17 PM
Dave_Darling   ...Is it just me, or are all three of those diagra...   Nov 18 2004, 05:38 PM
swood   Great info! My lights go up and down and the ...   Nov 18 2004, 07:05 PM
Dave_Darling   There is one fuse for each low beam element--two t...   Nov 18 2004, 07:10 PM
type47fan   Dave, it's just you! Check the difference...   Nov 18 2004, 07:29 PM
1973TwoLiter914   Clay - great visual ! I'm having issue wi...   Apr 29 2020, 02:08 PM
ClayPerrine   Clay - great visual ! I'm having issue w...   Apr 30 2020, 12:15 AM
partwerks   Clay - great visual ! I'm having issue ...   Sep 30 2021, 06:46 PM
ClayPerrine   In the last paragraph. Is that something that coul...   Oct 2 2021, 11:02 AM
partwerks   In the last paragraph. Is that something that cou...   Oct 2 2021, 04:03 PM
iankarr   This may help…fwiw…I ended up wiring mine back...   Oct 2 2021, 12:24 PM
ClayPerrine   All 914-4s had a 2 speed wiper. There was an optio...   Oct 2 2021, 06:32 PM
- Lo-Fi Version Time is now: 29th April 2025 - 06:34 PM
