914fun |
Member ![]() ![]() Group: Members Posts: 107 Joined: 22-June 08 From: Joplin MO Member No.: 9,201 Region Association: Southwest Region ![]() |
After my rebuild i need to know if this looks right. When i was putting it together i thought i fallowed the instructions of tom Wilson's book. But i may have done something wrong. With the piston at top of stroke the red mark it lined up but the rotor is between 1and 2 at the cap with the mark on the dizzy pointing to the case deciding line. If you look close there is a mark to the left of the red one and that correspondence to a factory mark on the opposite sidethat i thought should be showing with the piston at the top. But its not showing but the red one shows. The mark on the flywheel is dead center though. Can someone guide me from here? The motor is a 1.8Lt, 96 pistons stock crank, scat cam for carbs, 34 ict dual carbs. Thank
Attached thumbnail(s) ![]() |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
914fun,
Your engine looks good. How did you get the engine case so clean? Or is that finish paint? (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 05:37 PM |
