Distributor, Install |
914fun |
Aug 22 2018, 01:34 PM
Member Group: Members Posts: 107 Joined: 22-June 08 From: Joplin MO Member No.: 9,201 Region Association: Southwest Region |
After my rebuild i need to know if this looks right. When i was putting it together i thought i fallowed the instructions of tom Wilson's book. But i may have done something wrong. With the piston at top of stroke the red mark it lined up but the rotor is between 1and 2 at the cap with the mark on the dizzy pointing to the case deciding line. If you look close there is a mark to the left of the red one and that correspondence to a factory mark on the opposite sidethat i thought should be showing with the piston at the top. But its not showing but the red one shows. The mark on the flywheel is dead center though. Can someone guide me from here? The motor is a 1.8Lt, 96 pistons stock crank, scat cam for carbs, 34 ict dual carbs. Thank
Attached thumbnail(s) |
914_teener |
Aug 22 2018, 02:09 PM
914 Guru Group: Members Posts: 5,208 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I'll let others comment on the mark.....
You should take the caps off both sides of the advance can if you are not going to use it. |
jcd914 |
Aug 22 2018, 06:31 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
nditiz1 |
Aug 23 2018, 06:27 AM
Senior Member Group: Members Posts: 1,193 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I'll let others comment on the mark..... You should take the caps off both sides of the advance can if you are not going to use it. Why? If the advance is not being used it should not matter if the ports are capped or open. Jim Never ever cap your advance even if you are not using it. As McMark says - tell your friends (IMG:style_emoticons/default/ph34r.gif) |
jcd914 |
Aug 23 2018, 08:04 AM
I'll let others comment on the mark..... You should take the caps off both sides of the advance can if you are not going to use it. Why? If the advance is not being used it should not matter if the ports are capped or open. Jim Never ever cap your advance even if you are not using it. As McMark says - tell your friends (IMG:style_emoticons/default/ph34r.gif) Sorry but I don't see a reason not to. If you are just using one side of the vacuum canister then you shouldn't cap the other side air needs to be able to go in and out of the unused side. If the vacuum advance is not used, then capping either or both sides will have no impact on any other function of the distributor. The mechanical advance does not move the vacuum advance mechanism. Jim |
Lo-Fi Version | Time is now: 25th June 2024 - 06:08 PM |
