Beyond frustrated!, installation of triangle seal, glass , and front track- seal too long, tight, door cant shut and to top it off the bottom adjuster, was stuck, broke! |
DRPHIL914 |
Aug 11 2018, 04:49 PM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
beyond frustrated- i am going to have to source a replacement assembly with a good adjuster- anyone have one send my way cheap or free??
spent the better part of the last 4 hours trying to get the doors done. unable to complete because the drivers door bottom adjuster nut that is attached to the front track that also holds the triangle window was rusted bad and snapped off- second was , before that happened being unable to get triangle glass seal in(too long) and down enough so could not get door to shut. pulled it all back out and now i cant decide how to proceed! Attached thumbnail(s) |
dr914@autoatlanta.com |
Aug 23 2018, 09:04 AM
914 Guru Group: Members Posts: 8,114 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Have you tried the URO vent glass seals to compare? After all of this frustration, it is just not worth continuing to fool with a seal that is hard to fit. We often try several different brands before finding one that works best. Right now there are factory, URO and 914 rubber.
Fitting the seals and getting the doors and windows to close properly and not leak IS a hassle no doubt |
Lo-Fi Version | Time is now: 6th January 2025 - 07:26 PM |
