Beyond frustrated!, installation of triangle seal, glass , and front track- seal too long, tight, door cant shut and to top it off the bottom adjuster, was stuck, broke! |
DRPHIL914 |
Aug 11 2018, 04:49 PM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
beyond frustrated- i am going to have to source a replacement assembly with a good adjuster- anyone have one send my way cheap or free??
spent the better part of the last 4 hours trying to get the doors done. unable to complete because the drivers door bottom adjuster nut that is attached to the front track that also holds the triangle window was rusted bad and snapped off- second was , before that happened being unable to get triangle glass seal in(too long) and down enough so could not get door to shut. pulled it all back out and now i cant decide how to proceed! Attached thumbnail(s) |
Mikey914 |
Aug 23 2018, 10:47 AM
The rubber man Group: Members Posts: 12,742 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You can try the URO seal, but if the top cap fits on, and the base is fully installed the window is at the proper height. How the window interacts with the door and top gap is an adjustment of the bar.
The only advantage / disadvantage the URO seal has is the hole that lets water into the door. You would not need to modify the tab to not have the hole. |
DRPHIL914 |
Aug 23 2018, 11:04 AM
You can try the URO seal, but if the top cap fits on, and the base is fully installed the window is at the proper height. How the window interacts with the door and top gap is an adjustment of the bar. The only advantage / disadvantage the URO seal has is the hole that lets water into the door. You would not need to modify the tab to not have the hole. what it looks like right now is when the window is in the seal ans installed in the track, its so tight and too wide and long so i cant get the front end and leading edge of the glass back down and back far enough to not hit that car seal, and then of course the door will not close, |
Lo-Fi Version | Time is now: 6th January 2025 - 07:02 PM |
