Beyond frustrated!, installation of triangle seal, glass , and front track- seal too long, tight, door cant shut and to top it off the bottom adjuster, was stuck, broke! |
DRPHIL914 |
Aug 11 2018, 04:49 PM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
beyond frustrated- i am going to have to source a replacement assembly with a good adjuster- anyone have one send my way cheap or free??
spent the better part of the last 4 hours trying to get the doors done. unable to complete because the drivers door bottom adjuster nut that is attached to the front track that also holds the triangle window was rusted bad and snapped off- second was , before that happened being unable to get triangle glass seal in(too long) and down enough so could not get door to shut. pulled it all back out and now i cant decide how to proceed! Attached thumbnail(s) |
Mikey914 |
Aug 23 2018, 11:20 AM
The rubber man Group: Members Posts: 12,742 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
To be honest this one had me swearing quite a bit too. The window in the front does tuck underneath however the back needs to rotate down so as long as the base of the seal is fully engaged into the door it should be a matter of the center of the track coming back just a little.
In other words adjustment for and aft |
Lo-Fi Version | Time is now: 6th January 2025 - 07:25 PM |
