> how to adjust the alignment of the trunk hinge, when the trunk is opened the drivers side hinge hits the left small grill piece
DRPHIL914
post Aug 26 2018, 09:34 AM
Dr. Phil
So how can this be adjusted- the hinges were replaced by Tangerine Racing a couple years ago with the aftermarket JWest ones. i dont remember that happening thought until after i got the car back from paint. probably only need about a 1/8” shift backward.
jim_hoyland
post Aug 26 2018, 04:38 PM
Get that VIN ?
Having just installed the JWest replacement hinge kit, I can see how this could have happened. I followed the JWest instructions to a T ( they are posted on his web site ). After removing the OEM brackets, I attached the trunk hinges to the JWest brackets. Then with the trunk centered and closed marked the new holes, carefully keeping the bracket at the correct angle ( very important step)
Bolted both sides up and came out perfect
Post a picture of your bracket so we can see how it’s positioned
- Lo-Fi Version Time is now: 6th January 2025 - 09:11 PM
