KeithTurk |
Newbie ![]() Group: Members Posts: 27 Joined: 9-August 18 From: Enterprise Alabama Member No.: 22,375 Region Association: South East States ![]() |
Couple of quick questions. My headlight door motors work great but the headlights don’t come on. I happen to have another headlight switch that’s proven but it failed to fix the issue.
It’s on a 1974 914 If that’s relevant Is there a headlight relay somewhere or something I should look at? My turn signals flash quickly and I only have one brake light. Is it the same as the turn signal and the bulb just burned out? Hmmm ( I can check that pretty quick ) |
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,270 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
Not wanting to hijack this thread but I'm following to diagnose mine. I have power to the red|white wire when the switch is pulled but when I bypass the relay and hook up the white or yellow the voltage reading goes to zero? I've checked the continuity to the head lights and no problems now I'm stuck
Lo-Fi Version | Time is now: 22nd February 2025 - 11:37 AM |
