Steering U-Joints |
Steering U-Joints |
aylanco |
Nov 18 2004, 09:20 PM
Member Group: Members Posts: 106 Joined: 19-July 04 From: Ann Arbor, MI Member No.: 2,371 |
Hi All,
My new-to-me '73 2.0 is in need of the Turbo tie rods for sure, but I am a little suspect about the steering u-joints under the dash. They seem tight when I grab or wiggle them, but if I turn the wheel I can feel (and hear) them undulate. They just feel a bit sloppy when turning the wheel. I have seen almost nothing discussed about them, have not seen anything in books/manuals other than identifying them, and have not seen them offered in parts catalogs. I know the Rodders use them and they are available that way BUT....does anyone have any insight on the maintenance and or replacement of these? I know I should do the tie rods first but is this u-joint problem a common occurence? BTW, this 914 is too cool. I have hardly driven my other cars since I got this!!! (IMG:style_emoticons/default/mueba.gif) |
KenH |
Nov 18 2004, 09:39 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
Jack the car up so the front wheels are not on the ground. Then see if the steering still feels bad.
Also the U-joints are not linear and the 2 must be alingned propelry or the steer wheel will feel like it is going "over center" - not rotating smoothly. Look under the dash you should not see any slopp in the joints as the steering wheel is moved back & forth. Just some thougths Ken |
Lo-Fi Version | Time is now: 28th June 2024 - 01:03 AM |
