ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
I have all of my vacuum hoses connected (new) and I have a hole open on the throttle body. Any should this hole be left open?
For reference, I have added Mr. Bowlsby's nifty diagram. Also, please note that the picture of the throttle manifold (body?) is from ebay, could not get a good shot of mine. Thank you all 914-ers! Attached thumbnail(s) ![]() Attached image(s) ![]() |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
It is a welded in metal support tube that goes all the way through the plenum.
It does not open into the plenum, just goes through to the bottom. There is another one on the other side of throttle plate flange. The plenum often cracks around these tubes and creates vacuum leaks. Jim |
ctc911ctc |
It is a welded in metal support tube that goes all the way through the plenum. It does not open into the plenum, just goes through to the bottom. There is another one on the other side of the throttle plate flange. The plenum often cracks around these tubes and creates vacuum leaks. Jim Whew - this hole was driving me crazy - THANKS JIM! |
Lo-Fi Version | Time is now: 28th June 2024 - 07:57 PM |
