ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
To all ECU/MPS/TS2 people!
I have a '74 2.0L that I am resurrecting to be original equipment with the exception of all of the Hell-Hole parts which are Rest-Design or other vendors. The problem that I have been admiring for 2-3 weeks is one of White Smoke, or richness that begins after the engine has been running for 1-2 minutes. Background: ’74 2.0 barn find, 20K miles all indications are this is accurate (brake pedal wear, rotor wear, seat wear, all other used car tricks, etc….) Replaced fuel system tank to injectors Replaced all vacuum hoses Replaced all other fluids Replaced Hell hole, longitudinal, floor pans. Body – perfect, really, really good. Engine started, sounds like a swiss watch – no mechanically ‘noise’ just mechanical music…. A little rough, however – too much engine motion in the bay As the engine warms, the injectors are told to put way too much fuel into the system, white smoke and rich exhaust smell start after 40-60 seconds of operation. Here is what else I did so as to learn as much as possible about the process. I bought a second MPS from a 911World - great guy, very engaged and supportive (THANKS!). I also bought an ECU from him. When I received them, both checked out as ’74 2.0 numbers. Great, though the new MPS is a bit leaky, it compares to the numbers of the one I had which I replaced the diaphragm I put the two MPS units (the one I got with the car and the one I bought) on the bench and here are the numbers - very similar - My H meter is not calibrated so I believe since the two are VERY similar that I have a calibration problem… Setting____Reference__New Diaphragm___Purchased though leaky 0 inHg._____1.45_______1.06______________1.15 4 inHg--------1.24_______ .94_______________ .96 15 inHg______.75_______.66_______________ .66 1. I have tried both MPS units – operates the same, white smoke starts after a minute or two. 2. I Swapped the ECU units – operates the same, white smoke starts after a minute or two. 3. Replace the TS2 with a rheostat (variable resistor) tried it at 1K/500/300 - I believe it changed the time before the white smoke….takes a bit longer, have not timed this effect yet. I have not done anything with TS1 (Air temp sensor) since it has a marginal effect on mixture (see https://members.rennlist.com/pbanders/ecu.htm Common Questions) Talked to the guy who rebuilt the injectors and he has never seen a stuck injector which would stop being stuck when the car is off. (The fuel rail holds 30lbs for hours so injectors close when off). I am centering the MPS/ECU/TS2 part of this equation. Will keep digging, ANY advice would be very welcome! |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,484 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
Sure looks like oil smoke. Does it smell?
ctc911ctc |
After I posted the video I realized that the car in the background (my daily driver) with its blue background makes the smoke look Blue....sorry about that, but the smoke is white and smells like very rich exhaust.
I tested the exhaust using a white clean sheet of paper, then held it against the exhaust for 10-15 seconds. If it is oil (this test I remember from high school so it could be a complete failure) then there will be residue on the paper. The paper is clean after 15 seconds. Thank you for the post CK. CTC Sure looks like oil smoke. Does it smell? |
Lo-Fi Version | Time is now: 26th June 2024 - 09:21 AM |
