Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Well as some may know, my 2.3 massively spun the rear main bearing. Even though I have not opened the case, the debris in the oil tell me that the crank and likely the case is gone.
I think I can reuse the heads and pistons and cylinders. But I am assuming all of the other internals are toast. Pulled the oil pump and filter and there was no visible metal in these but there had to be parts of that bearing coming off for a while before it failed. Any thoughts on trying to reuse crank, cam, and case? Or should I just start building from another case? This engine had 98 mm P/Cs on it. I thought I recalled that the largest P/Cs that could be fitted were 96mm without opening the case. |
Mblizzard |
OK As you may have seen a broken crank. How this did not destroy everything in the engine including the valves I will never understand.
![]() ![]() But placed order today with Type 4 Store for a rebuild kit. Going with 102 mm Nickies, JE Pistons with 22 mm pins, 78 mm crank, H-Beam 5.325 rods, close version of the 86b Webcam, and lots of other good Type 4 bits and parts. Now as the saying goes "some assembly required!" |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:16 PM |
