Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Well as some may know, my 2.3 massively spun the rear main bearing. Even though I have not opened the case, the debris in the oil tell me that the crank and likely the case is gone.
I think I can reuse the heads and pistons and cylinders. But I am assuming all of the other internals are toast. Pulled the oil pump and filter and there was no visible metal in these but there had to be parts of that bearing coming off for a while before it failed. Any thoughts on trying to reuse crank, cam, and case? Or should I just start building from another case? This engine had 98 mm P/Cs on it. I thought I recalled that the largest P/Cs that could be fitted were 96mm without opening the case. |
Mblizzard |
It’s a good day when you come home to a huge shipment from the Type 4 Store! Special thanks to Charles and Nicole for dealing with all the questions and getting me the parts I needed.
Jamie |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,038 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States ![]() ![]() |
It’s a good day when you come home to a huge shipment from the Type 4 Store! Special thanks to Charles and Nicole for dealing with all the questions and getting me the parts I needed. ![]() Looks a bit early for Christmas deliveries, but good for you! (IMG:style_emoticons/default/santa_smiley.gif) |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:48 PM |
