Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Well as some may know, my 2.3 massively spun the rear main bearing. Even though I have not opened the case, the debris in the oil tell me that the crank and likely the case is gone.
I think I can reuse the heads and pistons and cylinders. But I am assuming all of the other internals are toast. Pulled the oil pump and filter and there was no visible metal in these but there had to be parts of that bearing coming off for a while before it failed. Any thoughts on trying to reuse crank, cam, and case? Or should I just start building from another case? This engine had 98 mm P/Cs on it. I thought I recalled that the largest P/Cs that could be fitted were 96mm without opening the case. |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
So Nickies? all new P's and C's? still doing the 2.7?
Mblizzard |
So Nickies? all new P's and C's? still doing the 2.7? Technically 2.5. Essentially everything but the case is new. Yes Nickies. True works of art. With JE forged pistons, H-beam rods, new crank, cam, head bolts, and all the other goodies. Still deciding on the new heads. Got to get the case to the shop for line bore and opening up for the 102's. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:24 PM |
