Is there an easy way?, Replacing rubber brake lines |
Carlitos Way |
Nov 20 2004, 01:34 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
Hi,
I'm wondering if there's an "easy" way to remove the rubber brake lines. I can get the lower part out, no problem... but is there a trick to removing the top part? hard to get in there and break it loose. thanks, Carlos |
davep |
Nov 20 2004, 04:13 PM
914 Historian Group: Benefactors Posts: 5,163 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
There is no easy way. I often use my plumbers torch to heat the joint. You have to be very careful doing that. First, drain the line, you don't want fluid in it if you use a torch. Apply a little heat, and try the flare wrench. The plumbers torch is acetylene without the oxygen, and makes a very small hot flame; small controlled flame is the reason I use it, and why I don't use a propane torch. An assistant with fire control equipment on hand is a must when I try this. |
Lo-Fi Version | Time is now: 30th June 2024 - 10:41 PM |
