Motor is tight when turning by hand |
swood |
Nov 6 2004, 10:14 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Ok, I've finally cut the p-rods and am loading them in and adjusting the valves. Right now it's on TDC for #1. I notice that when I turn the flywheel, at some point in the rotation there is a little tightness for a few degrees, maybe a 1/4 turn or so. My jugs were opened to 96mm with new KB's and hastings rings. Could this be just the rings on one of the pistons when down low in the cylinder? I don't know how free a new motor is to turn. The crank turned smooth as silk before connecting the rods, p&c's etc.
My hands hurt from the teeth on the flywheel so any thoughts would be great. |
swood |
Nov 20 2004, 08:35 PM
QUOTE(skline @ Nov 20 2004, 06:24 PM) I have some of them spacers if you want them, I have no use for them and there are 3 different sizes. You can mix and match to get the desired results. Hey Scott thats cool thanks. I'll take you up on that. |
Lo-Fi Version | Time is now: 21st September 2024 - 06:53 PM |
