Is there an easy way?, Replacing rubber brake lines |
Carlitos Way |
Nov 20 2004, 01:34 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
Hi,
I'm wondering if there's an "easy" way to remove the rubber brake lines. I can get the lower part out, no problem... but is there a trick to removing the top part? hard to get in there and break it loose. thanks, Carlos |
JoeSharpOld |
Nov 20 2004, 11:01 PM
Does it seem cold to you Group: Members Posts: 361 Joined: 29-April 04 From: Camping in Neverland Member No.: 2,001 |
The best way I found to do the rear was to remove the motor. But then sence you've got the motor out why not do the??? And it will be on jack stands forever. (IMG:style_emoticons/default/biggrin.gif)
Joe |
Lo-Fi Version | Time is now: 30th June 2024 - 10:53 PM |
