Is there an easy way?, Replacing rubber brake lines |
Carlitos Way |
Nov 20 2004, 01:34 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
Hi,
I'm wondering if there's an "easy" way to remove the rubber brake lines. I can get the lower part out, no problem... but is there a trick to removing the top part? hard to get in there and break it loose. thanks, Carlos |
IronHillRestorations |
Nov 21 2004, 02:58 PM
I. I. R. C. Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Only use vicegrips or pipe wrenches as a last resort. These will damage the hex fittings on the hard brake line, making use of a "real" wrench difficult if not impossible.
DJ is right about the penetrating oil. I've used the PB Blaster stuff for a couple years not, and it really works great. The best way to get to the upper fittings on the rear rubber lines is with a flare crowfoot, through the water drain hole in the engine shelf. This is a trick I got from Brad Mayeur. |
Lo-Fi Version | Time is now: 30th June 2024 - 10:07 PM |
