Transmission leak, Did I mess up with the gaskets? |
ambergris |
Nov 21 2004, 11:32 PM
Newbie Group: Members Posts: 22 Joined: 2-June 04 From: Mountain View, CA Member No.: 2,145 Region Association: Northern California |
Hey everyone,
I recently rebuilt my transmission. My first attempt at such a job, and I used RedBeard's very helpful article. So now it shifts great, but it leaks. As I drive, tranny oil is getting all over my exhaust and leaving a smelly smoke trail behind. It looked like the oil was pooling mostly at the end cover, and on the right side, so I thought it was the speedo drive and replaced the O-ring. Still leaking. Now I'm wondering if I screwed up those paper gaskets. When I took the thing apart, there was 1 paper gasket between the end cover and intermediate plate, and 3 paper gaskets between the plate and housing. I thought all of them had the color of oil soaked brown paper. I had purchased a Pelican transmission gasket set, and it came with 1 cover/plate and 3 plate/housing gaskets, and they were all brown. So I thought perfect! I'll just use them all. At this point, I'm not sure what my next steps should be. Anybody want to throw some suggestions out? |
Demick |
Nov 22 2004, 09:56 AM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
You shouldn't use any sealant between the intermediate plate and the main case. As Clay said, the thickness of the paper gaskets here is critical to the pinion/ring gear mesh. So it makes no sense to match this thickness, and then throw in sealant, which adds thickness. Most gasket maker sealants are RTV. This will add about .001" of thickness wherever it is used. So if you have 2 paper gaskets, and you add sealant to either side and between the gaskets, you have added about .003" to your stackup for pinion/ring gear mesh.
There are some sealants that don't add thickness - such Permatex 3H, which is what is used between engine case halves. The thickness of an RTV or Silicone sealant is why those sealants aren't recommended for sealing engine case halves. So the same reasoning applies to the transmission intermediate plate where the thickness of the gaskets is critical. So if you are going to use a sealant between the intermediate plate and the main case, use a sealant that won't add thickness. Demick |
Lo-Fi Version | Time is now: 22nd June 2024 - 07:37 PM |
