> 914World Classifieds Rules
> Through-the-Hood Filler Kit
Marek
post Oct 27 2018, 01:38 PM
FS: Through-the-Hood Filler Kit for 914
Finally
The kit contains all you need, to make your "through the hood filler look" complete
with out any welding or painting !!!!
the kit includeds
* Original 100mm vented Blau fuel cap, in stainless steel with a 5 hole fin
* A bolt on fuel neck you screw direct on to your tank , gaskets to adjust the height
you can combine the gasket depending on the height you need
* A "Dog bowl" to overfill fuel or rain it has a 1 m long drain tube,
on top it has a rubber seal, so its tight closing against the hood, without damage
* A Stainless bezel to mount on the hood, by screwing it on, with the incl 6 screws
btw every bolt , screw etc you need are included incl a shortl instruction
the only work you have to do your self is
*messure up and drill a hole 127 mm in your bonnet , use some epoxy primer on the edge
*remove the expansion tank on top of the tank by unscrewing the 8 bolts
*screw on the Fuel kneck , it got the correct angle put gaskets under it to get the height
( BE AWARE YOU CAN ADJUST THE TANK IT SELF A BIT ,SO MAKE SURE ITS STRAP´ ON THIGHT BEFORE YOU DO ANYTHING )
*put on the dog bowl ,mount the gasket and drain tube ,use silicone to set the height of the dogbowl
*screw on the top stainless or silver bezel with the included 6 stainless screws to the "under the hood" bezel , you might need to shorten the screws os they dont scrath the rubber seal , and use a drop of loctite to be sure the screws a lock thight
A silver mat painted cap / bezel option is available , see pics later in the post
For those of you that are not a fan of the screw on bezel on the hood , there is a option!
For the 911 kit we offered a square adapter you see on the last picture
its easy and simple and you get the perfect "hole in you hood" but its requiers welding / paint job
This version is also on stock now with a Silver or polished
Price 350 EURO + shipping ( to USA 37€ ) - 445 USD incl postage to US
Importen Do note !!!
I am shipping by DHL from Germany which is the cheapest option, I have been using them the last 10 years , so full tracking number never had a problem
BUT expect up to 4 weeks delivery , DHL said its long security checks in at US customs
Paypal ok, BUT save 25 EURO by a direct bank wire
By interest drop me a mail early911parts@gmail.com
I have posted some pictures below and much more to come ASAP
Regards
Marek ( Denmark )
johnvan8
post Nov 20 2018, 04:08 PM
Very interested. What is the best way to figure out exact location to cut hood? Is there a template or is it better to cut specifically to where your tank/hood are located in relation to each other?
Marek
post Nov 20 2018, 04:57 PM
QUOTE(johnvan8 @ Nov 20 2018, 02:08 PM) *
Well john , no template but I can post some ruff messurements to point you in a direction ,
but we can not make a template due to the bonnet and tank can be a few mm off in messurement on every car
so it requiers some messuring , I can tell how we did
we removed the expansion tank on top of the tank by unscrewing the 8 bolts
we tape the fuel opening with papper tape
we marked a cross on the center of the fuel openning
then we drilled a small hole 20 mm or so ,as closed to the center mark as we could predict
and when we saw we are close to center we did the hole larger and larger step by step
hope it gives an idea
Marek
johnvan8
post Nov 20 2018, 05:33 PM
QUOTE(Marek @ Nov 20 2018, 02:57 PM) *
Marek
That makes sense. Start with a small hole and go larger to center the opening, not the other way around! How long to ship to California?
Marek
post Nov 20 2018, 05:43 PM
Sorry to California you should expect UP to 4 weeks
Sorry its the cheapest shipping I found from Denmark
Fedex, UPS are 200 usd (IMG:style_emoticons/default/evilgrin.gif)
QUOTE(johnvan8 @ Nov 20 2018, 03:33 PM) *
Marek
Marek   Through-the-Hood Filler Kit   Oct 27 2018, 01:38 PM
Marek   The finish look mounted More installation picture...   Oct 27 2018, 01:44 PM
sfrenck   :popcorn: Take some pics of the finished product...   Oct 27 2018, 03:38 PM
pdlightning   Sure looks pretty!   Oct 27 2018, 09:13 PM
jmitro   looks great; i'll be interested pending your o...   Oct 28 2018, 06:46 AM
Chi-town   Can I get it in non-polished?   Oct 28 2018, 09:24 AM
burton73   Can I get it in non-polished? If you send it ou...   Oct 28 2018, 09:41 PM
BuddyV   Can I get it in non-polished? If you send it o...   Oct 28 2018, 10:53 PM
Chi-town   Can I get it in non-polished? If you send it o...   Oct 28 2018, 11:31 PM
Marek   Hi Guys I will post more pics asap from the inst...   Oct 29 2018, 01:52 AM
Chi-town   Silver painted works :D   Oct 29 2018, 10:18 AM
ValcoOscar   FOR ME...I like the last image of Post #1...weld i...   Oct 29 2018, 10:38 AM
mb911   FOR ME...I like the last image of Post #1...weld ...   Nov 20 2018, 04:38 PM
Marek   Hi Oscar the weld in trim is included, Marek ...   Nov 20 2018, 05:00 PM
ValcoOscar   Hi Oscar the weld in trim is included, Marek [...   Nov 20 2018, 05:20 PM
Marek   Sure no problem just drop me a mail when you are r...   Nov 20 2018, 05:23 PM
rgalla9146   FOR ME...I like the last image of Post #1...weld ...   Nov 20 2018, 09:36 PM
Marek   Sorry guys , forgot that the boys in the shop had ...   Nov 5 2018, 01:01 PM
Marek   Silver painted version , tested and on stock The...   Nov 19 2018, 02:54 PM
johnvan8   Very interested. What is the best way to figure ou...   Nov 20 2018, 04:08 PM
Marek   Very interested. What is the best way to figure o...   Nov 20 2018, 04:57 PM
johnvan8   Very interested. What is the best way to figure ...   Nov 20 2018, 05:33 PM
ValcoOscar   [quote name='Marek' post='2667226' date='Nov 20 2...   Nov 20 2018, 05:40 PM
johnvan8   [quote name='Marek' post='2667226' date='Nov 20 ...   Nov 20 2018, 07:31 PM
ValcoOscar   [quote name='ValcoOscar' post='2667239' date='Nov...   Nov 20 2018, 08:00 PM
Marek   Sorry to California you should expect UP to 4 week...   Nov 20 2018, 05:43 PM
larryM   long time back, Martin Baker was making & sell...   Nov 22 2018, 11:26 PM
johnvan8   @Marek : are there any unwanted consequences to re...   Nov 23 2018, 09:47 AM
pdlightning   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 22 2019, 10:18 AM
914forme   I'll be in for one with the weld on ring trim....   Nov 24 2018, 09:07 AM
Marek   BUMP But I am mostly interested in any feedback :...   Jan 9 2019, 11:03 AM
totle   Nice looking kit   Jan 9 2019, 04:57 PM
Marek   3 more kits in the mail to US :-) Thanks   Mar 11 2019, 03:47 AM
Niclas_Swe   Would be great to have a pic where you see more of...   Mar 22 2019, 07:35 AM
Marek   Bumped Come on guys show some pics :-) of your b...   Sep 12 2019, 01:36 PM
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 8th February 2025 - 09:56 AM
