> Fuel pump wires, Location
trojanhorsepower
post Nov 23 2018, 02:46 PM
Believe it or not, I cant seem to find them in my harness. Not that they aren't there, I just don't know what they look like. So my understanding is that on a 73 the pump is located under the engine shelf, but all the wires go into the engine bay via the snorkel, so do the pump wires pass back down through the engine shelf?..
JeffBowlsby
post Nov 23 2018, 09:00 PM
914 Wiring Harnesses
The late cars required a 12ga wire and ground to the front for the FP.
barefoot
post Nov 24 2018, 07:23 AM
QUOTE(JeffBowlsby @ Nov 23 2018, 10:00 PM) *
The late cars with the front mounted pumps had wires in the harness in the front
(Black with red bands for power and brown ground)
trojanhorsepower   Fuel pump wires   Nov 23 2018, 02:46 PM
jcd914   They run along the top of the engine shelf with th...   Nov 23 2018, 03:11 PM
JeffBowlsby   Where are you looking for them within the harness?   Nov 23 2018, 03:18 PM
trojanhorsepower   OK, so maybe these two? Two largish red wires ...   Nov 23 2018, 06:54 PM
yellowporky   looks like them   Nov 23 2018, 07:03 PM
clapeza   I couldn't find mine either. A previous owner ...   Nov 23 2018, 07:04 PM
trojanhorsepower   Thanks all! Now I just need to figure out how ...   Nov 23 2018, 07:27 PM
trojanhorsepower   Any idea what the little green wire with the black...   Nov 23 2018, 08:11 PM
yellowporky   I just did mine on my 73 last week. Here is what i...   Nov 23 2018, 08:48 PM
JeffBowlsby   The late cars required a 12ga wire and ground to t...   Nov 23 2018, 09:00 PM
barefoot   The late cars required a 12ga wire and ground to ...   Nov 24 2018, 07:23 AM
trojanhorsepower   Looks good. Did you notch out the base of the sno...   Nov 23 2018, 09:07 PM
yellowporky   i guess i will re run 12 gauge wire now. No i did...   Nov 23 2018, 09:22 PM
trojanhorsepower   Ah, i see now, you ran it in through another hole ...   Nov 23 2018, 10:47 PM
trojanhorsepower   So what about the little green wire with the black...   Nov 25 2018, 03:59 PM
JeffBowlsby   So what about the little green wire with the blac...   Nov 25 2018, 04:09 PM
SirAndy   So what about the little green wire with the blac...   Nov 25 2018, 04:11 PM
trojanhorsepower   Got it. Now how long should it be. The wire is a...   Dec 1 2018, 04:18 PM
- Lo-Fi Version Time is now: 15th January 2025 - 09:24 AM
