> Un-used wiring under the center carpet behind the shifter
Tdskip
post Nov 25 2018, 10:58 AM
First of all thank you for everybody's patients with all the questions I've been peppering the forum with.
I'm going into do my shift or pushing today and noticed these when I pulled the carpet back. This is obviously factory wiring, and I believe these were in every car but simply unused if you didn't order the appearance package that had the center consul. Is that correct?
Before I dig out a wiring diagram does anyone know offhand what these are for?
Thanks!
DickSteinkamp
post Nov 25 2018, 12:47 PM
OK...that makes sense.
I think the only wire you will be able to use from the optional console wiring will be the temperature sending unit to gauge. The others would be for a clock and voltmeter.
Tdskip   Un-used wiring under the center carpet behind the shifter   Nov 25 2018, 10:58 AM
bbrock   Those are for the optional center console gauges.   Nov 25 2018, 11:04 AM
Tom_T   Those are for the optional center console gauges....   Nov 25 2018, 11:19 AM
defianty   :agree:   Nov 25 2018, 11:09 AM
Tdskip   Thanks for the confirmation gentlemen. So I can u...   Nov 25 2018, 11:44 AM
DickSteinkamp   Thanks for the confirmation gentlemen. So I can ...   Nov 25 2018, 12:24 PM
Tdskip   Thanks for the confirmation gentlemen. So I can...   Nov 25 2018, 12:31 PM
SirAndy   Thanks for the confirmation gentlemen. So I can u...   Nov 25 2018, 12:55 PM
Tdskip   Thanks for the confirmation gentlemen. So I can ...   Nov 25 2018, 12:58 PM
SirAndy   [quote name='SirAndy' post='2668584' date='Nov 25...   Nov 25 2018, 12:59 PM
Jamie   Thanks for the confirmation gentlemen. So I can ...   Nov 25 2018, 01:02 PM
SirAndy   [quote name='SirAndy' post='2668584' date='Nov 25...   Nov 25 2018, 01:07 PM
worn   [quote name='SirAndy' post='2668584' date='Nov 2...   Nov 25 2018, 01:20 PM
Tdskip   Hi, thank you for the response . Yes, I know I do...   Nov 25 2018, 01:15 PM
SirAndy   Yes, I know I don't have the sender but I shou...   Nov 25 2018, 01:16 PM
DickSteinkamp   OK...that makes sense. I think the only wire you ...   Nov 25 2018, 12:47 PM
Tdskip   OK...that makes sense. I think the only wire you...   Nov 25 2018, 12:55 PM
bbrock   Here's the other end of that sender wire in th...   Nov 25 2018, 01:18 PM
Tdskip   Thanks Brent!   Nov 25 2018, 03:56 PM
JeffBowlsby   P had a specific cable for connecting the dash mou...   Nov 25 2018, 04:19 PM
horizontally-opposed   P had a specific cable for connecting the dash mo...   Jan 24 2021, 06:56 PM
Tdskip   Thanks Jeff   Nov 25 2018, 08:18 PM
sixnotfour   check the red one   Jan 24 2021, 07:17 PM
rhodyguy   You should put the other combo gauge in.   Jan 24 2021, 07:20 PM
JeffBowlsby   Pete the clock circuit should be live +12V full ti...   Jan 24 2021, 07:40 PM
horizontally-opposed   You should put the other combo gauge in. Thanks...   Jan 24 2021, 07:42 PM
- Lo-Fi Version Time is now: 15th January 2025 - 02:35 AM
