Un-used wiring under the center carpet behind the shifter |
Tdskip |
Nov 25 2018, 10:58 AM
Advanced Member Group: Members Posts: 3,703 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
First of all thank you for everybody's patients with all the questions I've been peppering the forum with.
I'm going into do my shift or pushing today and noticed these when I pulled the carpet back. This is obviously factory wiring, and I believe these were in every car but simply unused if you didn't order the appearance package that had the center consul. Is that correct? Before I dig out a wiring diagram does anyone know offhand what these are for? Thanks! |
Tdskip |
Nov 25 2018, 11:44 AM
Thanks for the confirmation gentlemen.
So I can use those, once I source the proper sender, with this then, correct? |
SirAndy |
Nov 25 2018, 12:55 PM
Resident German Group: Admin Posts: 41,972 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Thanks for the confirmation gentlemen. So I can use those, once I source the proper sender, with this then, correct? Like said above, the only thing useful would be the oil temp wire (green/black), which you could extend up into the gauge cluster to run the combo gauge. (IMG:style_emoticons/default/shades.gif) PS: The other end of that wire should be located on top of the engine shelf under the battery tray, next to the hell hole. That's where the temp sensor would plug into. |
Tdskip |
Nov 25 2018, 01:15 PM
Hi, thank you for the response .
Yes, I know I don't have the sender but I should have the wiring/connections sitting there unused? |
Lo-Fi Version | Time is now: 15th January 2025 - 02:32 AM |
