> Un-used wiring under the center carpet behind the shifter
Tdskip
post Nov 25 2018, 10:58 AM
First of all thank you for everybody's patients with all the questions I've been peppering the forum with.
I'm going into do my shift or pushing today and noticed these when I pulled the carpet back. This is obviously factory wiring, and I believe these were in every car but simply unused if you didn't order the appearance package that had the center consul. Is that correct?
Before I dig out a wiring diagram does anyone know offhand what these are for?
Thanks!
bbrock
post Nov 25 2018, 01:18 PM
Here's the other end of that sender wire in the hell hole. This end is connected to a special 1-wire harness that leads to the taco plate @SirAndy mentioned that covers the sender. Jeff Bowlsby sells those and I've included a pic of the one a made to replace my old crackly one. When you are sourcing a taco plate, try to get those wire brackets as well because I don't think they are included with Jeff's harness.
(IMG:http://www.914world.com/bbs2/uploads/post-20845-1536198452.jpg)
Tdskip   Un-used wiring under the center carpet behind the shifter   Nov 25 2018, 10:58 AM
bbrock   Those are for the optional center console gauges.   Nov 25 2018, 11:04 AM
Tom_T   Those are for the optional center console gauges....   Nov 25 2018, 11:19 AM
defianty   :agree:   Nov 25 2018, 11:09 AM
Tdskip   Thanks for the confirmation gentlemen. So I can u...   Nov 25 2018, 11:44 AM
DickSteinkamp   Thanks for the confirmation gentlemen. So I can ...   Nov 25 2018, 12:24 PM
Tdskip   Thanks for the confirmation gentlemen. So I can...   Nov 25 2018, 12:31 PM
SirAndy   Thanks for the confirmation gentlemen. So I can u...   Nov 25 2018, 12:55 PM
Tdskip   Thanks for the confirmation gentlemen. So I can ...   Nov 25 2018, 12:58 PM
SirAndy   [quote name='SirAndy' post='2668584' date='Nov 25...   Nov 25 2018, 12:59 PM
Jamie   Thanks for the confirmation gentlemen. So I can ...   Nov 25 2018, 01:02 PM
SirAndy   [quote name='SirAndy' post='2668584' date='Nov 25...   Nov 25 2018, 01:07 PM
worn   [quote name='SirAndy' post='2668584' date='Nov 2...   Nov 25 2018, 01:20 PM
Tdskip   Hi, thank you for the response . Yes, I know I do...   Nov 25 2018, 01:15 PM
SirAndy   Yes, I know I don't have the sender but I shou...   Nov 25 2018, 01:16 PM
DickSteinkamp   OK...that makes sense. I think the only wire you ...   Nov 25 2018, 12:47 PM
Tdskip   OK...that makes sense. I think the only wire you...   Nov 25 2018, 12:55 PM
bbrock   Here's the other end of that sender wire in th...   Nov 25 2018, 01:18 PM
Tdskip   Thanks Brent!   Nov 25 2018, 03:56 PM
JeffBowlsby   P had a specific cable for connecting the dash mou...   Nov 25 2018, 04:19 PM
horizontally-opposed   P had a specific cable for connecting the dash mo...   Jan 24 2021, 06:56 PM
Tdskip   Thanks Jeff   Nov 25 2018, 08:18 PM
sixnotfour   check the red one   Jan 24 2021, 07:17 PM
rhodyguy   You should put the other combo gauge in.   Jan 24 2021, 07:20 PM
JeffBowlsby   Pete the clock circuit should be live +12V full ti...   Jan 24 2021, 07:40 PM
horizontally-opposed   You should put the other combo gauge in. Thanks...   Jan 24 2021, 07:42 PM
- Lo-Fi Version Time is now: 15th January 2025 - 02:28 AM
