Transmission Blasting, Aluminium Oxide 100 grit OK |
rstover |
Nov 28 2018, 08:34 PM
Member Group: Members Posts: 136 Joined: 15-November 11 From: Austin, TX Member No.: 13,785 Region Association: Southwest Region |
I recently had the fan housing cerakoted and now I want to do the transmission. On the fan housing I removed all the grease and oil and the shop that applied the cerakote blasted it withe 200 grit aluminium oxide in a cabinet and it came out great.
I will get all the grease and oil off the transmission, but the blasting will be done with 100 grit aluminum oxide outside of a cabinet. I believe I have protected everything but was a little concerned about 100 grit being to course. |
mepstein |
Nov 28 2018, 08:58 PM
914-6 GT in waiting Group: Members Posts: 19,702 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would only soda blast unless you intend to overhaul the trans after blasting.
rstover |
Nov 28 2018, 09:11 PM
Lo-Fi Version | Time is now: 15th January 2025 - 05:50 AM |
