Transmission Blasting, Aluminium Oxide 100 grit OK |
rstover |
Nov 28 2018, 08:34 PM
Member Group: Members Posts: 136 Joined: 15-November 11 From: Austin, TX Member No.: 13,785 Region Association: Southwest Region |
I recently had the fan housing cerakoted and now I want to do the transmission. On the fan housing I removed all the grease and oil and the shop that applied the cerakote blasted it withe 200 grit aluminium oxide in a cabinet and it came out great.
I will get all the grease and oil off the transmission, but the blasting will be done with 100 grit aluminum oxide outside of a cabinet. I believe I have protected everything but was a little concerned about 100 grit being to course. |
brant |
Nov 29 2018, 10:18 AM
914 Wizard Group: Members Posts: 11,831 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I agree with all of the above comments
to the OP you will not keep 100% of the media out that media will in turn ruin your bearings and then you will be spending 2k on the rebuild in 2 years please if your going to blast... use dry ice or soda. something that will dissolve and definitely not a silica media. That is the wrong way of doing this job |
Lo-Fi Version | Time is now: 15th January 2025 - 05:39 AM |
