1bad914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 ![]() |
Anyone used a 944 radiator on an SBC V-8 conversion, I have one and was measuring it for size, it would fit well and has dual puller fans, plus temp sensors built in. You could also use the over flow tank! Just a thought! Not sure if it has the cooling capacity or not?
Randy |
neo914-6 |
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 ![]() |
If the parts are "free" then you just need to consider your time and fabrication resources. You can calculate all day long to but to know if it will actually work means at least fabricating mounts and duct work, possibly modifiying the inlet/outlets, wiring the fans, etc. Then if it doesn't work, you may have to start over.
Good luck, Felix |
Lo-Fi Version | Time is now: 2nd July 2024 - 01:50 AM |
