> Replacing trunk hinge, Success, and hinge bolt mod.
Olympic 914
post Dec 4 2018, 02:38 PM
Going to have to repair/replace the trunk hinge on the car this winter. It was repaired before.... but it failed in a different spot. I wonder if the trunk lid gasket was too tight and caused this failure?
I am planning on taking the engine out to make it easier to get in there and position it correctly and do a good job welding.
How many of you have done this repair leaving the engine in?
I am not an experienced welder and trying to weld it while bent over the fender and trying to even get the mig in there seems too hard.
I have already had the engine out twice since last Oct. so I am getting quite good at it.
post Dec 4 2018, 02:40 PM
914-6 GT in waiting
If you don’t need it to be original, Jwest makes a bolt in trunk hinge kit.
Olympic 914   Replacing trunk hinge   Dec 4 2018, 02:38 PM
mepstein   If you don’t need it to be original, Jwest makes...   Dec 4 2018, 02:40 PM
jcd914   If you don’t need it to be original, Jwest make...   Dec 4 2018, 06:10 PM
dr914@autoatlanta.com   engine in easy if you can spot weld, and now with ...   Dec 4 2018, 05:14 PM
dr914@autoatlanta.com   by the way in the back of the tech tips 700 is the...   Dec 4 2018, 05:15 PM
Olympic 914   by the way in the back of the tech tips 700 is th...   Dec 4 2018, 05:59 PM
dr914@autoatlanta.com   the bottom of page 132 by the way in the back o...   Dec 5 2018, 03:22 PM
Olympic 914   Damn.... My copy only goes to pg 125. :huh: :hi...   Dec 5 2018, 06:05 PM
914werke   The failure mode isn't tension, but rust. Or m...   Dec 4 2018, 06:34 PM
914_teener   The failure mode isn't tension, but rust. Or ...   Dec 4 2018, 06:54 PM
amfab   +2 for the JWest system. Hardest part was getting ...   Dec 5 2018, 02:58 PM
rgalla9146   See current thread...'Replacing bracket for h...   Dec 5 2018, 08:10 PM
Tdskip   I haven't done it (yet) but I believe the JWes...   Dec 6 2018, 08:16 AM
Olympic 914   OK, decided to pull the engine to do this job. ...   Jan 26 2019, 03:00 PM
second wind   OK, decided to pull the engine to do this job. ...   Jan 27 2019, 01:44 PM
914forme   :agree: They look great, that trick was published ...   Jan 26 2019, 06:12 PM
Olympic 914   :agree: They look great, that trick was published...   Jan 26 2019, 08:45 PM
914forme   :agree: They look great, that trick was publishe...   Jan 26 2019, 11:04 PM
IronHillRestorations   Bingo! That's what I call the "Upfix...   Jan 26 2019, 09:04 PM
windforfun   I replaced my plastic rollers with metal ones. I ...   Jan 27 2019, 11:23 AM
second wind   So......any chance of making a bunch of those nift...   Jan 27 2019, 01:47 PM
- Lo-Fi Version Time is now: 12th April 2025 - 02:27 AM
