Rod911964 |
Unregistered ![]() |
Greetings and HELP
Purchased a 1974 914, 1.8L FI. This Porsche has not been started in 24 years. So I have... Replace the tank Replace every fuel line Replace fuel pump Rebuilt injectors New Spark Plugs Replace all vacuum lines New Cap & points New spark plug wires checked for spark (got it) Check fuel pump function (OK) Checked for vacuum leaks (none found) Checked AFM (made lean, the changed back to orig. setting) So my problem. The engine starts for only a moment, say about NMT 10 seconds then dies out. Upon cranking the starter I am getting a lot of raw gas in the exhaust system, so much its spitting out the pipes. I collect about 3-4 ounces is a catch tray. Could I have the fuel tank lines reversed? So what am I doing wrong or what is wrong. Thanks in advance. |
Rod911964 |
Thanks all,
So the next on the list is to... 1) 4 baby food jars and check the injector flow rates 2) Check (and replace) Cyl Head Temp Sensor 3) Adjust dwell at Distributor Report to follow. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:56 AM |
