Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Hello gentlemen, hope everyone is having a good week so far.
My '73 only has a temp warning light and I'd like to know that it is good before I push the car into regular use. I'm clearly struggling trusting the car absent gauges that give me the information I'm used to.... Pull and ground one of the leads? Thanks! |
Tdskip |
Hi George!
So, effectively, is the light coming on when ignition is turned on and then off when running all the test I need? Thanks. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
So, effectively, is the light coming on when ignition is turned on and then off when running all the test I need? Yes, as long as you stop referring to it as a "temp warning light" ... oil temperature != oil pressure (IMG:style_emoticons/default/shades.gif) |
Tdskip |
So, effectively, is the light coming on when ignition is turned on and then off when running all the test I need? Yes, as long as you stop referring to it as a "temp warning light" ... oil temperature != oil pressure (IMG:style_emoticons/default/shades.gif) Can I call it a flux capacitor? (IMG:style_emoticons/default/evilgrin.gif) |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
So, effectively, is the light coming on when ignition is turned on and then off when running all the test I need? Yes, as long as you stop referring to it as a "temp warning light" ... oil temperature != oil pressure (IMG:style_emoticons/default/shades.gif) Can I call it a flux capacitor? (IMG:style_emoticons/default/evilgrin.gif) No |
Tdskip |
So, effectively, is the light coming on when ignition is turned on and then off when running all the test I need? Yes, as long as you stop referring to it as a "temp warning light" ... oil temperature != oil pressure (IMG:style_emoticons/default/shades.gif) Can I call it a flux capacitor? (IMG:style_emoticons/default/evilgrin.gif) No LOL, Oil temperature warning light it is then |
Lo-Fi Version | Time is now: 26th June 2024 - 09:07 AM |
