Ansbacher |
Senior Member ![]() ![]() ![]() Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 ![]() |
First off, yes I know the 050 is not a good choice for the 914- heard all that a thousand times before, but I stumbled upon a NOS one and want to try it out on my carbureted '74 2.0L to see for myself how it performs.
Here is my question - When I used an 050 on the '64 356SC I used to have, the number 1 plug wire went from the normal 5 o'clock position to the 7 o'clock position. This was normal for an 050 when installed in a 356 engine. Will I run into the same sort of thing when installing an 050 in a 914? In other words will all my plug wires be shifted one position clockwise? Ansbacher |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
It depends on how you install the distributor and the drive shaft. The best thing to do would be to set up the car at TDC#1, then pull out the old distributor. Look carefully at the slot in the drive shaft down in the case, and the tangs at the bottom of the distributor drive. Compare to the drive tangs on the 050. Spin until the tangs are the same orientation, then look to see where the slot on the shaft for the rotor is.
--DD |
Lo-Fi Version | Time is now: 20th June 2024 - 09:21 AM |
