dennisphelan |
Newbie ![]() Group: Members Posts: 15 Joined: 10-December 18 From: Dundee Oregon Member No.: 22,713 Region Association: Pacific Northwest ![]() |
Trying to put back together 75 1.8 as a 2.0 D-Jetronic. Engine is in the car. I am trying to hook up the 12 pin connector on the relay board. One of the wires (according to Jeff Bowlsby's drawing - thank you Jeff) is supposed to go to the Oil Pressure Switch. I can't seem to locate it. Where is it?
I also have two components under the Battery Tray. One is black and appears to have something plug into it. It has multiple spade connectors. The second one is hanging from several twisted copper wires and is a plug with several spade connectors. Are these something left over from the 1.8 FI system? Are they needed anymore? |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
The green/red wire is the oil pressure sender wire. Sender is below the tin near the dizzy. Photos for the other things please.
dennisphelan |
[quote name='JeffBowlsby' date='Dec 22 2018, 02:31 PM' post='2675858']
The green/red wire is the oil pressure sender wire. Sender is below the tin near the dizzy. Photos for the other things please. I think I found the oil pressure sensor. Unfortunately, I destroyed the rubber grommet when I tried to remove it. I have attached a picture of the tow components attached to the battery tray ![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 07:52 PM |
